Standard 4Spd To 5Spd
hey guys just a quick question I couldn't find an answer to
I have a stock as a rock ke70 with what I beleive to be a k40 4 speed and someone I know is selling a k50
5 speed
q- will the k50 bolt straight into my car without changing anything?
if not what must be modded to fit the k50?
cheers ben
p.s they selling the k50 for $100 bux
HI MATE idid the exact same coversion 3 yrs ago . for memory i recalled that it was basically a straight forward conversion which used the original 4 speed tailshaft .i recall yhat all
HI MATE SORRY ABOUT THE UNFINISHED ANSWERS I POSTED I AM NEW TO THIS AND STILL LEARNING anyway i basically removed a 5 speed box from a ke70 corolla which had the 4kc engine in it and as far as i remember it all bolted up using the 4 speed crossmember and the 4 speed tail shaft and for memory on the highway when in 4th gear and changing to 5th it was approximatly a 200 rpm drop and i know for a fact that both 4 and 5 speed gear boxes have identical 1st t0 4th gear ratios . i hope this helps. CHEERS DOMENIC
you have help me gears thanks to both of you
legends
I really appreciate it my rolla is getting there ;) 
