Haystack Posted November 12, 2011 Report Share Posted November 12, 2011 (edited) Hi guy's, I'm new here. I have just aqured an old AE82 and fitted a 4age 16v bigport to it. I have changed the whole wiring loom (Engine bay and Dashboard) and fuse boxes (3) and i can only get it to start on thr cold start injector. It starts for about 1-2 seconds then stops. I believe i have tracked the problem down to the No 2 EFI relay. The relay tests and works fine on the bench but, I cannot get power to it thru footwell fusebox. I replaced that fusebox and still no pwer to the relay. Any Ideas???? PS. I have positive battery current at both sides of thr injector plug and no pulsing during cranking. Edited November 12, 2011 by Haystack Quote Link to comment Share on other sites More sharing options...
Haystack Posted November 22, 2011 Author Report Share Posted November 22, 2011 Hi Guy's, I know I did not get a reply but in the time since then I have found several things. 1. Australian AE 82s don't have a No 2 EFI relay. (Only Japan US and Europe) 2. Checking the injector signal is nearly impossible unless you have speacilised EFI test equipment. Anyway I fixed the problem by running full fuel pressure (Fuel pump Relay bypass) and signaling each injector several time each using an adapter I made. After doing this the engine now runs very well. It appears that the injectors may have been a little gummed up or sticky. Cheers, Quote Link to comment Share on other sites More sharing options...
