November 22, 201114 yr comment_567525 Hi all I'm about to put my 5k engine & 5speed box into my panelvan just wanted to know weather i can use the clutch assy from my 4k/4speed? also is there any other problems i may bump into? Report
November 22, 201114 yr comment_567527 use the 4k clutch and flywheel. 4k flywheel/clutch is 180mm 5k is 200mm. the 5k flywheel/clutch will not fit inside the ke70/55 k50 bellhousing. Report
