December 11, 201114 yr comment_570958 Hey guys Have been searching around but havent found anything tha tells me what I'm after. I'm pretty sure the front end is exactly the same as th sedan, but I'm not sure on the wagon. Does anyone know what parts, if any, match up between sedan and wagon Edited December 11, 201114 yr by stockstandard Report
December 11, 201114 yr Author comment_571045 Yep should have mentioned I was after other options other than nolathane. Have used them in the past and have been less than impressed. have had better results with rubber, just having dramas sourcing gear for a wagon. Report
December 12, 201114 yr comment_571051 Ah ok, try Mackay rubber http://www.mackayrubber.com.au/catalogues/suspension.php Can get the stuff through these guys http://www.eziautoparts.com.au/suspension/suspension-bush-kits/mackay-suspension-bush-kits.html Nolathane has improved over the years but i still believe it does depend on where you use the stuff on the suspension. What i used on my old car (ke30) was nolathane on the castor rods, front sway bar, control arms and the shackles on the rear suspension (no rear sway bar). Everything else was rubber. Firmed up the suspension nicely but it didn't hurt the ride quality that much. Report
