scottiriver Posted January 2, 2012 Report Posted January 2, 2012 heyy all I'm looking at air conditioning for my ke70, and i know that there are two ways of doing it, 1. install after market, does anyone know of costs? 2. install a used system, does anyone know whats required and costs of these parts? cheers scotty Quote
Evan G Posted January 2, 2012 Report Posted January 2, 2012 $150 msg DPB on here. to suit ae71 4ac. so you might need different compressor and compressor lines Quote
scottiriver Posted January 2, 2012 Author Report Posted January 2, 2012 yeah saw that but hes in vic :( Quote
Ben-89 Posted January 2, 2012 Report Posted January 2, 2012 I have seen seen at least 4 or more with a/c when going through wreckers over the past few years. I suppose the ae71 under dash ac unit and ducting is usefull but the a/c pump bracket, condensor and lines are a different thing all together. Coincidentally I was reading about installing a/c and its quite involved. Better obtaining it off a complete car so you know you have all the associated bits together. (as highlighted in this ke70 aircon manual). Carby idle needs to be adjusted, along with the fitting of the vtsv valve which is on the passenger strut tower. And the chopping of vaclines to accomodate t pieces etc,etc. If you go genuine you this will usefull, aftermarket will be expensive. http://www.ke70.com/Toyota%20Corolla%20Air%20Conditioner%20Ke70%20Instructions.pdf Quote
Evan G Posted January 2, 2012 Report Posted January 2, 2012 i did a retrofit to my ke55. biggest job was removing the heater box to fit the evaporator. wiring was a little tricky aswell. rest was all straight forward Quote
Ben-89 Posted January 2, 2012 Report Posted January 2, 2012 Retro fit from what? AE71 or KE70 ac unit will go in as the firewall has the same grommet outlets heater core shouldnt be touched, in saying that its fiddly and time consuming. But its the issue of getting the proper plumbing for it. Most people get rid of them as A there old and don't work, or B its wasted power. You'll find one and if its for $150 grab it. I'm sure you could arrange something with dpb for the main bits. 1 Quote
just a rolla Posted January 12, 2012 Report Posted January 12, 2012 hey I'm not shor about putting aircon in but I'm chasing a ke70 aircon bracket so i can fit my sc14 to my 5k if any one can help msg me on 0402518919 Quote
