February 29, 201214 yr comment_587411 hey guys keeping the rolla and the 4k but am going to chuck a sc12 or a sc14 ? charger on there what are the steps and things youll need yo achieve this i no a fuel upgrade etc is need but what else etc Edited February 29, 201214 yr by kurtiz Report
February 29, 201214 yr comment_587416 Unfortunately there's no 'list of things'. You'll need to fab a bunch of stuff etc. You may be able to buy a ready to roll kit. Do you want lots of grunt and reliable, or are you just aiming to get some more power but you're not worried about reliability? Report
February 29, 201214 yr Author comment_587417 Unfortunately there's no 'list of things'. You'll need to fab a bunch of stuff etc. You may be able to buy a ready to roll kit. Do you want lots of grunt and reliable, or are you just aiming to get some more power but you're not worried about reliability? cheers mate and yeah more so after the power i bit of relibility but just a lil more of a kick i no it wont add much of a power gain but i just don't want to go down the same route is every1 with the 4age and sr20 etc and am on a budget lol Report
February 29, 201214 yr comment_587421 An SC12 will have to be under driven to make a "bit more" power as it almost displaces your engine displacement in one revolution. Just with the standard pulley I would say 15psi and that's a low estimation (only if the pulley is 1:1). A pulley ratio of 0.6 would get you 7psi and a slight step up of ratio to 0.75 will get you to 12psi. There is a tonne of info on how to supercharge your engine out there on the net it's hardly worth asking. Google is your friend. Also prepare to buy shares in K series diffs as you will chew through them if miss treated. Same as gearboxes. Look for an F series diff as it seems to be all the rage. Report
