hey guys, recently return the stock carby to my 4k, it had a weber, everythings hooked with imissions gear, turn over but wont start? Any help would be much appreciated
Bet you didn't connect .....
idle shutoff solenoid. Actually, it should start but not idle if that was the case.
If not, does it have spark at the plugs and can you see the fuel being sprayed in down the venturi by the accelerator pump??
How long has that stock carb been sitting around dry??
yea i did connect the idle solenoid, its gettin spark, it'l start if i pour a lil fuel down the carb then runs for a while, an not sure how long it was sittin for, as i got it from the wreckers
