April 6, 201214 yr comment_595580 can a 02 sensor cause a engine light to come on and make the car plater sometimes? the engine is a 4age 20 valve silvertop Report
April 6, 201214 yr comment_595587 Yes to the engine light, but I don't know what 'plater' is a typo for... Can you extract error codes? Report
April 8, 201214 yr Author comment_596055 Yes to the engine light, but I don't know what 'plater' is a typo for... Can you extract error codes? sorry mate that was meant to say splatter haha Report
April 8, 201214 yr Author comment_596058 and ill have to pay some 1 to put it on the diagnostic would it comne up error code if it was cause lat time it was on nothing came up Report
April 8, 201214 yr comment_596063 I don't know about the 4AGE, but the 3SGE in the Altezza has error codes that come up when you bridge two diagnostic pins. Its easy to do and anyone can do it. The engine light flashes codes in the diagnostic mode, but just stays on constantly when driving. That''s using OBD 1 I think, it was just before they went to OBD II. Someone on here will know if the 4AGE has that function. I assume you are running a stock ECU... I think problems with an oxy sensor would be logged. Report
