April 29, 201214 yr comment_600550 Had a fight with a sign post the other day. smashed the front grill, bent the radiator cross member, and bruised my pride. Q. as i don't have the car with me atm, is the radiator cross member a straight bolt in/out arrangement? or will i require the services of a panel beater? it was a low-speed collision and the fan only JUST brushes the radiator, so not too bad. any help would be appreciated. Report
April 29, 201214 yr comment_600551 Its spot welded so a new one will need to be spot welded back in. You could tie a rope to it, the other end to a tree and reverse slowly and pull it out but thats a but ghetto. Report
April 29, 201214 yr Author comment_600552 Its spot welded so a new one will need to be spot welded back in. You could tie a rope to it, the other end to a tree and reverse slowly and pull it out but thats a but ghetto. cheers jesus. know of any ke70 wreckers/specialists in adelaide? been to AJPS. good work, good guys. just seein whatelse is out there. Report
