VBlue Posted May 30, 2012 Report Posted May 30, 2012 My brakes are working fine, there is no metal on metal noise or anything unusual, but since I bought the car last year I didn't change any brake pads nor do I know when it was last done. I removed the wheel and just took a look, but I'm a bit confused as to what I should be exactly looking for. This was a picture of the left wheel side (passenger side), so the rusty bit on the right side of the opening is the part of the rotor: I didn't open unbolt the caliper because I'm at a friend's house and he doesn't have a proper sized socket wrench. I scratched a bit off what I thought was the friction material and that looks rather metallic to me so I was a bit worried that I've run out of the brake pad and now it's contacting the metal bit. Although the rotors look rather polished and even, nothing seems to be unusual, but I'm no expert. Am I in trouble? Quote
Sephiroth Posted May 31, 2012 Report Posted May 31, 2012 The little bit in the centre with the little arch cut out is your brake material and it looks like you got plenty there so don't be to concerned that they haven't been changed in a year My mums Telstar has had the same brake pads for atleast the last 5years as a matter of fact I serviced it last week and I think they've been growing lol 1 Quote
VBlue Posted May 31, 2012 Author Report Posted May 31, 2012 What really confused me was that I looked up the Max Ellery service manual and in the diagram in that, the metal backing (the shim or whatever it's called) has the arch and not the friction material, so it seems it's actually the other way around. Anyhow, thanks for the reply, will save me a bit of time and money not having to fiddle with that for a while. Cheers! Quote
Sephiroth Posted May 31, 2012 Report Posted May 31, 2012 What really confused me was that I looked up the Max Ellery service manual and in the diagram in that, the metal backing (the shim or whatever it's called) has the arch and not the friction material, so it seems it's actually the other way around. Anyhow, thanks for the reply, will save me a bit of time and money not having to fiddle with that for a while. Cheers! Ok that's a lil confusing about the manual but you can trust me I'm a mechanic When the arch arch is non existent or there's only a couple mm left of the friction material you should change them and best off getting new rotors or have them machined because new pads don't wear in very well on old rotors because the tend to warp from the heat of using them Hope that helps Cheers Jaesn Quote
