June 9, 201214 yr comment_608888 hey guys ive just bought my first ke30 corolla :).. ive decided on a sr20det conversion using s13 crossmember,r31 diff etc. i was just wondering whats the best hydralic clutch set up to use? pedal box etc. Report
June 9, 201214 yr comment_608906 TA22 or RA23 for the hydraulic clutch (master cylinder). Right next to where the clutch cable goes through the firewall is two bolts, the master cylinder bolts to it. You'll just have to drill a large diameter hole for the rod to go through. And just modify the clutch pedal. Or see if you can hunt up the pedal box from a TE3x or TE5x. Report
