July 30, 201214 yr comment_618682 Lookin at a pair of ae86 coilovers n i was wondering wether they will bolt into my 84 ke70??? I am a fabricator by trade but a straight bolt in swap would be nice. These r the coilovers I'm lookin at. http://item.mobileweb.ebay.com/viewitem?itemId=310404441590&index=11&nav=SEARCH&nid=75957699668 Report
July 30, 201214 yr comment_618691 Rear coilovers bolt straight up, but for the fronts you'll need discs, calipers, and steering arms, and possibly tie rod ends too. When I finish up with mine I'll let you know what I did (don't hold your breath though). Report
July 30, 201214 yr comment_618701 Riley is right, you will need those AE86 parts to put AE86 coilovers into a KE70, plus AE86 hubs and caliper brackets. However I thought I might add that those front coilovers you posted the link to will not work without original AE86 struts (AE86 strut tubes are 51mm diameter whereas KE70 struts are 45mm(?) plus KE70 hubs/brakes/steering arms do not fit up to AE86 struts) as the Megan coilovers don't have a stub axle, you have to modify your original struts by cutting off the strut tube and welding the coilovers to the stub axle. Taken from the Megan Racing website: "NOTE: Original spindles must be modified and welded onto the lower front brackets, similar to coil-over setups for the AE86 chassis. The front lower brackets are made of steel for this purpose." Edited July 30, 201214 yr by rian Report
July 30, 201214 yr Author comment_618725 Ok all that sounds like what i was expecting. Mayb i purchase a set of coilovers with a stub axel, n modify the brake mounting brackets n such too suit. Thanks for the reply fellahs Report
