chris-deals-cars Posted September 16, 2012 Report Share Posted September 16, 2012 hey rolla clubbers, basically going to do the good old sr20 ke70, but I'm going a highly modifed sr20de, the car itself i bought for $300 running, pretty weak condition. the motor is out of my brothers s13 as we went the DET conversion for him. mods on the motor : s14 blacktop non vvti, 800kms old since rebuild. : lighten flywheel, light weight pulley kit. : 550cc injectors, 8mm leads, : polished plenum, bigger TB. : cp forged pistons, eagle beam forged rods, knife edged crankshaft, turbo oil squirters, turbo block, turbo head. : shaved head, .30 thou, ported, : HKS 265/264 cams, valve springs retainers. pretty quick and tourqey engine. can easily bolt turbo manifold on and run turbo as motor been built for it. may condisder doing so yet not to sure if i can get my head around the r31 diff conversion. have the diff lined up just not sure if i can tackle that big of a job. so far the parts i have for the ke70 are. : s14 crossmember, steering rack, lcas, castor rods, knuckles, 5 stuf hubs, and s14 brakes. (not 100% sure if s14 stuff works ?) : hydro handbrake : intercooler : master cylinder, clutch pedal is in the process of getting fabricated. not sure on clearances as of yet. anyone knows of a good pedal and or box to use please do tell. thats all ive gathered so far, ill upload as many pics as i can and keep this build thread alive and running and not quit out, atm I'm un employed but doesnt mean i can't make/weld/fabricate some good stuff in the meantime. hope youse enjoy it and show some support ! cheers Quote Link to comment Share on other sites More sharing options...
chris-deals-cars Posted September 16, 2012 Author Report Share Posted September 16, 2012 this when i first bought the car, sanded down rear half, primed it, Quote Link to comment Share on other sites More sharing options...
chris-deals-cars Posted September 16, 2012 Author Report Share Posted September 16, 2012 rear half primered and smoooooothh Quote Link to comment Share on other sites More sharing options...
chris-deals-cars Posted September 16, 2012 Author Report Share Posted September 16, 2012 here is the s13 master cylinder bolted up, with a suzuki swift clutch pedal, and a bit of metal welded together, linesd up sweet as. Quote Link to comment Share on other sites More sharing options...
chris-deals-cars Posted September 16, 2012 Author Report Share Posted September 16, 2012 picture 1. here is the said 180kw sr20de engine. picture 2. is 4k coming out ! picture 3. gearbox cross member, just welding plates to the end the bolting on gearbox bolt motor in place then drilling holes to suit. picture 4. sr20 sitting in its new home. Quote Link to comment Share on other sites More sharing options...
chris-deals-cars Posted September 16, 2012 Author Report Share Posted September 16, 2012 well at this stage I'm cleaning out my garage to move this project under cover/lights/shade 24/7 so will be disctracted for a few days, once I'm moved ill be chopping out the front half of the car to do the box section rad support, and ill weld up a few supports like radiator and intercooler, for now peace Quote Link to comment Share on other sites More sharing options...
chris-deals-cars Posted September 20, 2012 Author Report Share Posted September 20, 2012 before... after..... under carriage clean fabrication area Quote Link to comment Share on other sites More sharing options...
Daizy70 Posted September 21, 2012 Report Share Posted September 21, 2012 This looks like its going to be a pretty sick ke, I'm keen to see how it goes Quote Link to comment Share on other sites More sharing options...
chris-deals-cars Posted September 21, 2012 Author Report Share Posted September 21, 2012 cheers man, it should be decent. still throwing in the air keep the DE or go DET/r31 diff etc.. Quote Link to comment Share on other sites More sharing options...
It's_AUDM_Yo Posted September 21, 2012 Report Share Posted September 21, 2012 Is it 180kw tested? Because JDM s15 sr20det's put out 180kw. No vvt sr20de's are about 110kw, so you reckon you've gained 70kw.... Â Nice build though. Keep it up. Quote Link to comment Share on other sites More sharing options...
chris-deals-cars Posted September 22, 2012 Author Report Share Posted September 22, 2012 when it was in a silvia it raced 185kw xr6 BA falcon manual and beat it, and 170kw magna that beat the xr6( :S ??) so i just rate it about that lol. but there is a fair amount of modifcations, will most defintly be putting on the dyno after the build./ cheers for the support fellas !! Quote Link to comment Share on other sites More sharing options...
chris-deals-cars Posted September 22, 2012 Author Report Share Posted September 22, 2012 cut out original rad support, re welded it with 25x25 gal box section. makes intercooler brackets/oil cooler brackets/tranny cooler brackerts bonnet pins much easier. cut out original rad support ect. much more room for airflow on radiator and intercooler.... even tho I'm going DE just incase i go DET. imo it looks pretty neat Quote Link to comment Share on other sites More sharing options...
mitchyie Posted September 24, 2012 Report Share Posted September 24, 2012 looks deadly! Quote Link to comment Share on other sites More sharing options...
It's_AUDM_Yo Posted September 24, 2012 Report Share Posted September 24, 2012 Intercooler?.......isn't it a sr20de Quote Link to comment Share on other sites More sharing options...
chris-deals-cars Posted September 24, 2012 Author Report Share Posted September 24, 2012 yeah dude, read the pics title its just incase i do run DET also to make the pic look better haha Quote Link to comment Share on other sites More sharing options...
