October 11, 201214 yr comment_631327 Looking at getting the "GL" style tail lights off eBay Has anyone got any off there? Any feedback on them? Does anyone know if they fit straight in? Report
October 11, 201214 yr comment_631328 They will bolt in, but you will need to rewire them. They have a different loom so will not plug in. What I did was use the old wiring loom. You will need to add an extra brake light circuit as they have two This involves pulling the bulb holders out. Its not super hard and doesnt necessarily require any soldering. Report
October 11, 201214 yr Author comment_631332 They will bolt in, but you will need to rewire them. They have a different loom so will not plug in. What I did was use the old wiring loom. You will need to add an extra brake light circuit as they have two This involves pulling the bulb holders out. Its not super hard and doesnt necessarily require any soldering. So fairly easy to do? Would you say it's worth the swap? Report
