October 16, 201214 yr comment_631943 hi all I'm liam very new to this site . well i will jump to it i am looking at buying my first corolla and really want a ke70 flat front with the qaud circle lights. i have been reading the forums and know u can do the conversions to make them like that but all the ke70's i have found have all been out of my price range . now i have stumbled across a ae71 and want to know can i still do the flat front and quad lights conversion on it and is it as good as a ke. then the next problem is need to make it manuel and just want to know where to go and how much its going to cost i live in brisbane as well so any help on this would be much appricated Report
October 16, 201214 yr comment_631945 Yes you can convert it but you will need every panel from the windscreen forwards. To make the lights fit you will need to also use the flat front radiator support or Fab up some mounts. If you go for the round quad light you will need to notch the front apron. Converting to manual will be quite pricey as everyone is after the AE71 manual pedal boxes. They are going for around $300 at the moment. Plus you'll need a manual T50 gearbox which are around the $200-$300 mark. Plus clutch master and slave. Edited October 16, 201214 yr by B.L.Z.BUB Report
October 17, 201214 yr Author comment_632117 thanks heaps for that so would it be worth buying this ae71 for 400 and spending the money to get it manuel . and to make it flat front and quad lights you need the front to panels and bumper and raidiator support and anything else. Report
