Just find a cheap but half decent aftermarket ecu for $200-300.... Then you'll actually hasn't tunability! Get a wolf 3d v4 and ill send you a map!
you already have a map for the 7k efi?
what were your dyno figures?
does any one know if a 5k manifold will bolt up to a 7k-e head?
the reason i ask is because i don't have the time to bugger around with the injection just yet. plan is to buy the donor engine throw it in with the 5k manifolds (if this is possible)
and then when i have more fit the injection
Sure will. Be aware that both the inlet and exhaust ports will be bigger than the manifold runners though. As I said earlier 7kc are the same size.
