hi just wondering if anyone has any info on fitting flat top pistons into a 3k . eg will the valves hit and would you have too much compression. i will be running a camtech 609 cam and a 3k-b twin carb setup.thanks
Not sure if 3k pistons can get any more flat top than they already are...
If your looking at increasing compression just get the head shave a bit.
Edited by GJM85
