April 3, 201313 yr comment_652107 So I'm running Fuzion 195/60/14r's With baby supra celica, Spent a pretty penny on tires, My car is an everyday driver, so for a quick fix, I ground the inner fender lip off with an angle grinder, I'm lowered 2inchs in the back and the front has stock cut springs, I don't weigh much but when I have a passanger if they are hefty I still get some rub and every time I see the rash on the side walls I die inside a little more. I plan to do some fender flares eventually , but are there other alternatives? Can I bend up the fenders? What about grinding more off, has anyone done this an achieved a clean look? I really only need like 1 inch to have no rub. Report
April 3, 201313 yr comment_652108 Depends how worried you are about your paint. Rolling the guards would be the ideal way. Cutting the inner lip leaves a sharp edge, most people will hammer it flat to the out side skin leaving a rounded edge. Then you can also push the flat edge around the arch out also. In saying that theres not much to work with on *E2* guards. Edited April 3, 201313 yr by B.L.Z.BUB Report
