April 30, 201313 yr comment_654825 Sup. I have been blessed with an almost rust free shell, my engine bay managed to soak up all the rust... I have been attempting to start the repairs my cleaning out my cooling system however, shortly after I changed over my radiator it sprung a leak. All my hoses and everything aren't leaking and it's a bit of a bugger to trace back. I'll bang up some photos and if you could give me a hand identifying/tracing back the leak. Having no actual cooling problems while driving, engine is still strong and stays cool. It's dumping a considerable amount of water/coolant even though it's just a consistent drip. There is no leak when the car is off, only when the coolant is flowing... Dripping off Highest I can trace to Edited April 30, 201313 yr by B-Lugg Report
April 30, 201313 yr comment_654827 Probably the water pump. Looks like its spraying water all around that area. Easy fix. Report
May 1, 201313 yr comment_654958 Yep water pump. They have a tiny little hole behind the shaft seals that is designed t leak when the seal dies, so you can tell its time to replace the pump. That's most likely where it's coming from. Report
May 11, 201313 yr Author comment_655774 Thanks guys. New water pump purchased and ready to go on tomorrow :). Report
May 13, 201313 yr Author comment_656062 Water pump replaced and it's no longer putting water down. Thanks for the help guys. Report
