November 16, 201312 yr comment_671876 Hi guys what is the highest static compression ratio that you have used with boost Report
November 24, 201312 yr comment_672394 I've seen 15:1 compression on a motor with 28psi of boost .... was a diesel powered Mack truck though, so perhaps not helpful in your situtation. A little more info might get you some more answers. Will depend on the engine and how 'laggy' you can live with. You could run 10:1 compression with 0.2bar boost, or you could run 8:1 with 1.5bar boost. Report
