1991 Nissan S13 - Project Car With All The Best Gear
Hey guys.
Unfortunately life has called for a change, so I am forced to sell my beloved Nissan Silvia project car.
I've had the s13 as a dedicated project for the past 4 years and have taken my time with every aspect of it.
Whilst still incomplete, no stone has been left unturned and once finished - would be hands down one of the best/cleanest examples of a s13 in the country.
As stated, the car has been a project - whilst rolling, it is currently not drivable [yet wouldn't require much work to get it so]
For the car to be drivable, the following would need to be done:
- remainder of front brakes installed
- remainder of fuel // cooling setup installed
- rewire the main harness
- new fluids throughout and alignment
- put back some of the interior
The car has remained registered for the past 4 years, despite not being driven.
No shortcuts have been taken whatsoever and only the best parts purchased [with reciepts pushing 30grand]
Please refer to my build thread on Nissan Silvia.
LINK: http://www.nissansil...=432891&st=1170
Some pictures:
Here are the specs of the car.
Note: All items are NEW and fitted only, unless otherwise stated]
- CAR -
1991 s13 Silvia Q's
80xxx on engine prior to rebuild
5000 approx since
140xxx on the shell
- CHASSIS -
Entire undercarriage sanded back to bare metal
Primed and painted in satin black sound deadener/stone guard
- UNDER THE BONNET -
Engine bay completely stripped and holes shaved
Battery tray and all brackets deleted
Stitch welded throughout
Bare metal respray in Toyota's Pegasus Pearl White
Deleted windscreen wipers
Aircon setup completely removed
DryCell battery relocated to boot
Red Line Tuning Bonnet struts
New OEM Grommets/Rubbers where applicable
- ENGINE -
REBUILT S14 SR20DE BY Donny of Forced Motorworks with:
BC Cams 264/264 12.05 lift (stage2)
CP forged pistons 10:1 CR 86.5mm
Nissan rods prepped and resized
Rocker Arm Stoppers
ARP rod bolts
Nissan gasket overhaul kit
1.2mm Cometic mls headgasket
MD spares head bolts
New Nissan water pump
BC valve springs
BC titanium retainers
Vision adjustable cam gears
New timing chain kit
Trust style bigger sump
King bearings
Block machined
Head machined, ported and polished
Fully Balanced
ATI Harmonic Balancer
Isis red billet aluminium pulleys
New Alternator
Nismo Engine mounts
Rocker cover painted in Mazda's Aluminium Metallic
Stainless Oil filler cap
- MANAGEMENT -
Haltech PS1000 Stand-alone ECU
Engine harness rewired (in progress)
- INTAKE & EXHAUST -
EFI Hardware Quad Throttle Body manifold
Pro-Race Tapered Bores: Sizes 52/50/48
[Jasma] 4-2-1 stainless extractors:
painted flame proof black and black heat wrapped
Full stainless steel 2.5inch exhaust with:
highflow cat/resonator/muffler finishing in twin 3inch tips
[sanded back and re-polished]
New nissan o2 sensor
New Nismo Exhaust hanger rubbers
New Nissan gaskets and mounting hardware
- DRIVETRAIN -
s14 sr20det 5speed Manual [cleaned and painted silver]
Nismo Gearbox mount
B&M Short Shifter
S13 manual tailshaft [refinished gloss black]
Exedy Lightened flywheel
Exedy Heavy Duty clutch
New Genuine Nissan Clutch Master Cylinder
New Genuine Nissan Slave Cylinder
New Genuine Nissan Needle Bearing
New Genuine Nissan dust boots / seals
ARP Flywheel bolts
HEL black braided clutch line
Chase Bays Tucked Power Steering kit
5bolt r200 4.1ratio Nismo 1.5Way Diff [repainted black / silver]
Rebuilt 5bolt halfshafts
- COOLING // FUEL -
Chase Bays Triple Core 60mm Tucked Alloy Radiator
Chase Bays Twin 10inch Thermo Fans
Davies Craig thermo fan relay switch
Chase Bays // CSR filler neck
Chase Bays // CSR polished radiator cap
Chase Bays Black Braided Radiator hoses
Mazworx Billet -AN Threaded Water Necks
Taark's Oil Block sandwich plate
GKTech Oil filter relocation black
[with braided lines and black ProFlow fittings]
Relocated / tucked stainless overflow reservoir
Nismo High Flow thermostat
Walbro GSS342 in-tank fuel pump
Chase Bays braided in-line fuel filter kit
Bosch Top Feed 370cc Injectors
Pro-Race billet aluminium fuel rail kit
PasswordJDM radiator cooling panel [painted satin black]
All clamps replaced by black anodized ProFlow fittings
All rubber hoses replaced with black braided items
- BRAKE SETUP -
r33 GTS-T Skyline brake calipers:
4pot front / 2pot rears [rebuilt and repainted black]
Chase Bays Brake Master Cylinder // Booster delete kit
Chase Bays brake proportioning valve
Chase Bays Tucked Braided in-bay Brake lines
HEL black s13 to r33 conversion Braided Brake Lines
Shiang-I Racing 5 stud conversion Hubs Front & Rear
New Nissan hub bearings all round
New wheel studs all round
Intima SR Street series brake pads all round
New Genuine Nissan r33 Handbrake cables
Eagle Handbrake cable Adapter
DBA 4000 series XS rotors front 297mm
DBA Street series GOLD rotors rear 296mm
[rotor hats stripped and repainted silver]
r33 backing plates painted black
New Genuine Nissan shoe linings
- WHEELS // RUBBER - [still in boxes]
RAYS Duraluminium Gunmetal Wheel Lock Nuts
RAYS Centre Caps
RAYS GRAM LIGHTS 57 Maximum Pro Wheels in RBC Finish
17x9+12 fronts // 18x10+10 rears
- SUSPENSION // HANDLING -
BC 'BR Type RA' Series Coilovers:
[spring Rates - F: 8kg // R: 6kg]
Reconditioned Steering Shaft and Rack
SRI black solid steering shaft bush
New Nissan OEM rack dust boots
SPL PRO Polyurethane rack bushings
SPL PRO // Tein Z33 Strengthened Tie Rods [with lock spacers]
SPL PRO Strengthened Tie Rod Ends
SPL PRO Adjustable Tension Rods
SPL PRO Adjustable Traction Rods [chrome finish]
SPL PRO Rear Upper Camber Arms [chrome finish]
SPL PRO Toe Rods [chrome finish]
Midnight Mods Rose Jointed Arm rubber dust boots
Whiteline Polyurethane Rear Subframe Bushes
[rear subframe reconditioned and painted black]
New JDM Obsession front and rear LCA Balljoints
Primal Garage Extra Lock Knuckles
GKTech Tension Rod brace
Whiteline 27mm Blade Adjustable front swaybar
Hard Race front swaybar linkages
Whiteline 20mm Blade Adjustable rear swaybar
Whiteline rear swaybar linkages
JJR rear strut bar [braces painted silver]
JJR front strut bar [braces painted silver]
UltraRacing fender braces
Remaining suspension items reconditioned & painted black
- ELECTRONICS - [none installed]
Custom cluster with Blitz guages:
52mm oil pressure
52mm oil temp
60mm tacho
52mm water temp
52mm vacuum
Custom HUD setup:
Defi HUD unit moulded into column surround
Custom cluster surround:
52mm digital fuel level guage
Push Start button [both flush mounted]
Custom built triple gauge vent setup:
52mm exhaust temp
52mm volt
52mm boost
180sx Type-X wiper/indicator stalks
- EXTERIOR - [none installed]
Genuine plastic Aero front bar
Genuine plastic Aero fog light grills
Genuine plastic Aero side skirts
New genuine Supermade Instant Gentleman rear bar
New carbon fibre Nismo 2 slat grill
New Origin carbon fibre weathershields
New Origin carbon fibre roof spoiler
Brick Headlights
New DMAX tinted corner indicators
New DMAX tinted front indicators
New DMAX tinted rear taillights
East Bear non-electric mirrors
+ more I've probably forgotten.
I am looking at moving the entire project as a whole, or mostly a whole - instead of parting out.
Depending on the price, certain things can either come or not come with the package/bundle.
This car is most likely aimed towards those looking at an all round track car // clean and tough streeter.
It will have the ability to perform well in either hill climbs, drift or circuit etc.
Pretty much just needs a paintjob and you're laughing.
I know E.O.I aren't allowed on here or offers, so I guess I'll put this up for a starting grade.
Obviously being that if someone is keen, they may not want certain things, so the price will differ in discussion.
For the sake of it; let's say $15,000.
Mind you the wheels are worth $3500 alone...
Please contact Rone/Josh by:
M: 0466 210 560
E: [email protected]
or PM me on here.
Located in Melbourne.
THANKS
Edited by shiryo
BUMP
MASSIVE PRICE DROP.
$10G FLAT
NO WHEELS, ITB'S OR GAUGE SETUP
