November 28, 201312 yr comment_672652 hi guys. this is my first time doing any sort of suspension on a car. my problem is my ke came with cut stock front springs i pulled out the front struts and fitted some stock springs. now i can't get the bolts in the engine bay to line up and it is killing me. do i need to take out steering arms and what not just to get them to line up?? thanks :) Report
November 28, 201312 yr comment_672653 Are you installing them on the correct sides, brakes forwards. The three strut top holes arent an equal distance apart. Or the spring tops are on the wrong struts. Edited November 28, 201312 yr by B.L.Z.BUB Report
November 28, 201312 yr Author comment_672654 Are you installing them on the correct sides, brakes forwards. The three strut top holes arent an equal distance apart. Or the spring tops are on the wrong struts. thanks for the reply yeah they are the correct sides and i took them to a shop to put the springs on as i don't have any clamps so i assume they would be fine unless they stuffed up. Report
November 28, 201312 yr comment_672658 Try putting one in the opposite side. If it fits the tops are on the wrong strut. Report
November 29, 201312 yr Author comment_672702 Try putting one in the opposite side. If it fits the tops are on the wrong strut. yeah turns out that is the case lol cheers for the help :bash: Report
