Hey all,
Thought i'd share my little project. its a 1990 model AE92 corolla CSX, which i've removed the Carby related side of the model which would mean its an SX model in theory hahaha
I've always dream't of a Corolla SX Sedan, i've had a liftback in the past but really wanted to try make something fun out of a Sedan model and heres what I got to:
1990 Toyota Corolla
Motor/Transmission
- 4AGE 16V Smallport Motor
- C56 Short Ratio 20V Gearbox
- Corolla SX EFI Fuel Tank Conversion
- 4-2-1 Hurricane Extractors
Interior/Body
- AE92 Levin Seats
- AE101 Gear Shifter
- AE101 Gear Knob
- 90s Mazda 626 Front lip
- Corolla SX Rear Seats
- Corolla SX Dash Cluster
- Corolla SX Body Loom
- Corolla SX Engine Bay Loom
- Corolla SX A/C Lines and Condensor
- 7" GPS/DVD Bluetooth Headunit
Brakes/Suspension
- Corolla SX Series 1 Front 238mm Vented Disc Rotors and Calipers
- Corolla SX Series 1 Rear Disc Calipers and Rotors
- Lowell Springs
- Corolla SX Front Sway Bar
- 18mm Whiteline Rear Sway Bar
- Corolla SX Front Control Arms
- Advan RG2 17x7 +40 offset Wheels
Planned Mods
- Emanage or other Aftermarket ECU
- 264 or 272 Degree Cams
- 2.25" Full Exhaust
AE92 GZE 258mm Rotors and calipers
- High Flow Cat
- Electric windows from Corolla SX Model
- Deep Dish Steering Wheel
- Full Nolathane/Whiteline Bush Kit throughout
- Whiteline Front Strut brace
Edited by sr_twincam
Love the attention to detail with this build. I was following it on MCM and an SX Sedan would've been awesome!
Well done, keep the updates coming :)
Oh mad thanks Ben, I'm hoping to take the attention to detail another level with some small touches which should make each bit on the car a bit different. Its been a heap of fun to muck around with and the end product was well worth it :)
After a huge headache dealing with the idler pulley on the p/s belt I ended up getting it to work. I also got around to properly sanding my letters so the surface is spotless now. I also got an intake pipe from the guy that was selling the extractors in echuca. It was a bit long so I needed to cut it down slightly. I am not sure if I am that keen on the blue on the silicone hose (ignore the OEM hose clamp with the 2 circles on the intake, I will change them asap). The intake pipe was sprayed with matt black. I think the overall look is coming up very nicely. The extractors aren't on yet, but once they are it should look even better.
The front end all assembled now. I am hoping the small touch of the red toyota logo on the grille looks alright. I thought it matches the red pinstripes quite well.
A shot of the back end. Definitely needs a new muffler on the rear. I will get this done when I get a 2.25" Cat back system. The great thing with how the car is sitting is that its 140mm off the ground so I don't have issues with ground clearances.
looks great mate, whats next for it?
Thanks mate :)
Good question actually, i'd like to say "LOTS" lol but i'm saving for a house at the moment (been saving for the last 7 years but cars always take money from the funds lol).
I'd like to get new a/c seals, get the system regassed and hopefully get a reasonable stereo in for those days I feel like chilling out.
Reaslistically I could see myself getting a 2.25" cat back system and a high flow cat. I'm hoping a second hand system will come up. Then I can just chuck on my hurricane 4-2-1 extractors and then the fun really starts hehe
After that maybe a mild set of cams and an aftermarket ecu may be added into the mix. Really i'd love a plug and play setup, the less cutting of the loom the better.
