March 16, 201412 yr comment_679526 hi guys, I'm about to undertake a 7k swap into my ke55. Would anyone have any photos of how much they had to cut out to clear the cross member? any helpful tips and advice woould be helpful thanks Report
March 16, 201412 yr comment_679529 i did it, and i used some spacers on the front engine mounts, had to weald a plate on top of the current bracket on the chassis to lift the engine about 1cm... fits perfect. Hold the engine in place to its spaced up to whatever space you want [mines about 8mm] and then pack the front mounts with spacers [larger washers about 1cm thick] OR do what i did, weald a plate on top of the mound on the car to lift everything. no different parts needed Report
