newjak
  1. cool thanks just wanted to put it out there so what is the measurment/\spacing between the three bolts?...
  2. hi guys, I've seen some people drill the tops of the strut tower to fit these but i was wondering has anyone drilled out the camber plate and relocated to stud to fit the KE55 spacing. i mean its easy to push out the stud in the camber plate, mark out the new position and repress in the stud. Therefore you don't need to drill the strut tower any on done this?? curious
  3. Cool thanks for the info What shocks should I get to match them? I also got a ottomoto sleeve kit for my ke55 struts, also need suggestion for shorter stroke shocks for these Cheers for the help guys
  4. they came out of a ke35 coupe and will be going into a ke55,
  5. hi guys i brought some reset leaf springs recently and noticed that the spring front eye bushes come in two different sizes (50mm and 35mm OD). Could you guys enlighten me as to which models had which size?
  6. anyone know where i can get my hubs and rotors redrilled ? need to get them redrilled to 4x114.3 I'm located in Rydalmere in sydney 2116
  7. hi guys, I'm about to undertake a 7k swap into my ke55. Would anyone have any photos of how much they had to cut out to clear the cross member? any helpful tips and advice woould be helpful thanks
  8. Thanks for all the replies guys, but a litlle messing around and i got it in, Ella...thanks for the offer, really appreciate that someone here actually offered to lend me a tool
  9. yes there should be a spring and also there should be an extra bit on the end of your clutch cable that hooks over the fork
  10. ke30driver , yes i went from auto to manual,K50 box, where can i get these parts?
  11. I'm sure this conversion has been done to death, anybody???
  12. hi guys, i have just finished installing my manual conversion and have found that the speedo cable is of a different size. also it is on the other side of the gearbox. I upgraded to a 5 speed and was wondering do i need to get a speedo cable from a KE70? or could some one measure there speedo cable (ke70) the threaded part that attaches to the gearbox, so i can compare to the one i have on mine. thank you in advance for the help
  13. sorry guys found the model corolla please disregard
  14. hey guys anyone got a clutch alignment tool i can borrow? putting in a new clutch for my 55
  15. can anyone tell what GRILLE this corolla came off ?? year??
