October 9, 201115 yr comment_559169 Hey just brought a ke70 and put a 5k in it (currently being turbo'd) But I'm having trouble setting up the clutch cable to the clutch for? Ill post some pics. Am i missing something. Thanks for the help!! Report
October 9, 201115 yr comment_559174 What seems to be missing? Why won't it fit? Does the 5K have a circular hole cast into the block to take the outer cable?? Have a search to check if the 5K is hydraulic & that people convert the car to hydraulics when they fit the 5K. Report
October 9, 201115 yr Author comment_559175 I'm using a k40 and I'm pretty sure the 5k isn't hydro. Could you post a pic of you clutch cable with the clutch fork and ill try sus out the problem. Thanks for the help :D Report
October 10, 201115 yr comment_559206 5K is cable and has the hole for it. The flange on the left where the cable comes through that should fit up against the hole through the block. I found on mine that the sandwich plate didn't have a corresponding hole (think I used the 3K one) and I had to drill it out in-situ. Also that big round sucker on the end of the cable doesn't look right, it should be a simple yoke that hooks over the clutch lever. Report
October 10, 201115 yr Author comment_559209 Thanks for help didn't think it looked right. Think i might just buy a new clutch cable. Also should there be a spring attached to the clutch fork? Report
October 10, 201115 yr comment_559232 yes there should be a spring and also there should be an extra bit on the end of your clutch cable that hooks over the fork Report
