Stud Pattern And Offset
Hi all,
Could anyone tell me what offset and wheel size is best for a Ke30 ?
Thanks
Hi it's been covered here before, but mostly I've found this link helpful. Ahaha.
http://lmgtfy.com/?q=ke30+wheel+size
A 7" rim all round is an easy fit with around a +15 offset, but you can likely fit an 8" on the rear with 0 offset.
13, 14 or 15" diameter depending on your preference, using a 114.3mm PCD.
You'll need a low profile tyre when using the larger diameter rims.
Edited by Mechanical Sympathy
this is with 14x7 wheels unsure of offset, 185/55/r14 tyres, lowered with molded flares
