June 1, 201412 yr comment_683531 I have a damaged KE36 windowed panel van for wrecking, located in Perth, WA Parts NOT AVAILABLE: - Tail lights - 3K engine and 4 speed box - Pedal box - Radiator - Tail shaft - Dash cap - Bumpers Will post most items at buyers expense. 0404 538 732 if you wish to call or txt http://www.gumtree.com.au/s-ad/bellevue/wrecking/wrecking-ke36/1047768821 Edited June 1, 201412 yr by Spectre Report
June 12, 201412 yr comment_684085 Hey Mate, Do you know if the door handles will fit a KE70 Panelvan, I'm struggling to find a drivers door handle, apparently there longer than sedan ones cheers Scott Report
August 1, 201412 yr comment_686403 Ke36 round headlight buckets and stainless steel trim mounting bits ?? Report
