KnightRolla Posted July 6, 2014 Report Posted July 6, 2014 Hi guys. My Ke70 interior light on the roof and my opened door warning light does not seem to be working. i have checked the fuse behind the kickpanel and the fuses seem to be intact and not blown. is there something else I'm missing? and my dash clock is not working as well. thanks for your help! Quote
Wog Boy Posted August 8, 2015 Report Posted August 8, 2015 Did you end up fixing this problem ? I have the same problems at the moment Quote
B.L.Z.BUB Posted August 8, 2015 Report Posted August 8, 2015 Pretty sure it's a fuse behind the drivers kick panel next to the accelerator Quote
Wog Boy Posted August 8, 2015 Report Posted August 8, 2015 Did you just replace a fuse to the amps states or higher ? I read that someone put a 10a fuse instead of a 5a Quote
