Ke30 - Window Wiper Not Enough Power
Hey guys.
My ke30s window wiper seems like it isnt getting enough power to it. Runs across the window twice then wont move again.
Will move fine if not against the window.. thoughts?
Check for dirty connections in the wiring plug at the wiper motor and also check all of the wiper mechanism joints for stiffness. You may have to remove the wiper motor for this to make it easy to inspect them. If all is good, check your voltage source and if its not that.......... could just be that your motor is getting tired,
cheers!
