Hey all, getting all the parts together for my build and doing research
I have and sr ready to go with gear box and mounts coming
Just wondering really about a fuel setup
Iv seen the hole vl lift pump and stuff but I have an idea for a more elegant solution, wether it would work I'm not sure
I was thinking something along the lines of an In car fuel tank in the boot with an internal pump like a modern car
Just can't seam to find one that I could buy
I will do the tried and test route of I can't find one
Just though I'd see if anyone knows anything like it
Cheers
Are you talking about an aftermarket fuel tank that sits inside the boot, or modifying your KE70 fuel tank, you can get a radiator place or such to cut open the top of your tank & weld in a swirl pot & fit a in tank hanger bracket & top cover plate etc, if you don't want to go that way I'm pretty sure the JDM AE86 tank fits in as a replacement tank & will have an internal pump & swirl pot etc which is what you want / need for EFI set up ..
Edited by lexsmaz
