Ke 70 Starter Relay Location?
Hi
I got a 1980 Ke70 with 4K, usually when i turn the ignition i can hear a relay click in when i try to start the car, but now theres nothing, and it seems no power is going to the starter when i try turn it. Battery and everything is fine, so i suspect its the relay, but where is it located?
Thanks for ur help, Tom
https://lh5.googleusercontent.com/proxy/2BKuHaCOTOjyp6cDAkj_wdTbW3YXq_WhASr3adaDUnaAHkYhECISF9t7Mfn2-clEB9IYfok8NbJjxXnuJhSnbdhuhcg6cJHo9scmgTXjVxIuHtir0IMMRyKu8VW2wf4fHK02enAJpotGXB3vwg=w301-h401-nc
Engine bay fuse box. You'll probably find its fine and it's the earth's in the ignition that are worn out. You can do a starter motor relay upgrade pretty easy.
Similar to this,
http://autofix.com.au/blog/fitting-an-auxiliary-starter-motor-relay
Edited by B.L.Z.BUB
