Kurt.mills98 Posted May 20, 2015 Report Share Posted May 20, 2015 (edited) Hi there I new to this sort of stuff but anyway I have a ke70 project car it has a 4a cross member in it ready for a 4a to be dropped in, but I'm having troubles with the gear box I assume I need a t series gearbox but does that mean I need to change the gearbox cross members from k40-t50 and if so how hard is that to do. And also with the diff do i need a ae71 manual tail shaft and will that fit a ke70 diff? Edited May 20, 2015 by Kurt.mills98 Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted May 20, 2015 Report Share Posted May 20, 2015 (edited) Hi there I new to this sort of stuff but anyway I have a ke70 project car it has a 4a cross member in it ready for a 4a to be dropped in, but I'm having troubles with the gear box I assume I need a t series gearbox Yup but does that mean I need to change the gearbox cross members from k40-t50 Yup and if so how hard is that to do. Easy, get an AE71 T50 cross member. And also with the diff do i need a ae71 manual tail shaft and will that fit a ke70 diff? Yup Yup. EDIT: Ensure you get an AE71/AE86 T50 box, other series like Celicea or T18 will ruin your day. Edited May 20, 2015 by B.L.Z.BUB Quote Link to comment Share on other sites More sharing options...
