GJM85 Posted May 22, 2015 Report Posted May 22, 2015 (edited) If your looking to run a cdi type box like msd there's a little issue with the internally regulated distributors for k motors It's common knowledge we use the original dizzy wire and we add a coil positive wire for the electronic distributor. If you use an alternate ignition source for that added wire then you can use the cd box with the same wiring configuration as for a points ignition. Edited May 22, 2015 by GJM85 Quote
