Crane/bosch Ignition Questions
gday all. i have a 5k/3k-b engine that i want to run with and an older crane 6600 ignition box and optical pickup dizzy that according to the crane tech guy will work together. My questions are, I have a bosch mec717 coil, do ineed the bim024 module to run it or does the box do it ? also i understand white wire from the dizzy sensor goes to white trigger wire on box, black to body earth, and then instuctions say red wire "12v+ switched" i assume this means to coil+ or should I put in a relay to get 12v+ from battery ? sorry if these are basic questions, cheers anyway .. :thumbsup:
Its straight forward really.
They wire up exactly the same as the MSD ignition controls I believe. I think they even have the same wire colouring.
No modules required.
I have a Streetfire CD ignition control (MSD 5520) with 5k internal ignitor dizzy and Bosch mec723 on my 5k.
hey gavin thanks for the info, no module is good news ... can't see the pic though mate. Ive got the pdf for the crane box now so that should help. thanks again
