Rolaspec Posted February 10, 2016 Report Share Posted February 10, 2016 Hi guys probably been asked a thousand times, are the standard fuel lines in the ke30 large enough to run surge tank or am I better off running a new feed and using the existing as a return line? Cheers Quote Link to comment Share on other sites More sharing options...
dandison Posted February 10, 2016 Report Share Posted February 10, 2016 From my experience, it's better as you said to run a new feed and use the existing line as a return line. That's what I've done for my Ke55 20V conversion and it works well :) Quote Link to comment Share on other sites More sharing options...
Rolaspec Posted February 10, 2016 Author Report Share Posted February 10, 2016 Did you use steel line? What size did you go with? Quote Link to comment Share on other sites More sharing options...
dandison Posted February 10, 2016 Report Share Posted February 10, 2016 (edited) Recommended minimum for 4AGE is 8mm feed and 6.3mm return I went with 10mm feed (Aeroflow stainless steel braided hose) and used the 6.3mm steel return (the original feed line) Got all my fuel gear (hose, attachments , surge tank, pump etc..) from Rocket Industries - good quality gear and good guys. Edited February 10, 2016 by dandison Quote Link to comment Share on other sites More sharing options...
dandison Posted February 10, 2016 Report Share Posted February 10, 2016 My engine is NA so not sure if this is the setup you'd want for Turbo... Quote Link to comment Share on other sites More sharing options...
Rolaspec Posted February 11, 2016 Author Report Share Posted February 11, 2016 Ok cool mate that's exactly what I'm after, thanks for the help appreciate it Quote Link to comment Share on other sites More sharing options...
