Ke30/ke55
I am wanting to upgrade the brakes on my KE20,i like the idea of using the original struts with the KE70 front discs/calipers & using the backing plate from the KE55 that i read in FAQ...Can i use a backing plate from either a KE30 or KE55? I have access to a KE30 wreck but was not sure if they are the same......
Kind regards Matt....
Yeah. 30 and 55 have same diameter rotor just different width. Same pcd as strut to bolt on but you'll need to drill and tap holes larger on the strut
Thanks Jono..That's good to now..
