Sign in to follow this
suwan4910
Ke70 Project
KTS front shock absorber with FC3S brake kit, which I assembled face shocks to fit into the daily use. And brake discs to be used as a mini R53 plate size 276 × 22 mm.
Share this post
Link to post
Share on other sites
The next item is watt link of SSWork. From Japan
By the pros
Normal of the undercarriage, hard coil, general coil, time it collapses - stretch It will sweep to the bend.
It will cause the shaft to move its left-right side along its sweep.
But Watt's link, it will keep the shaft does not move the left-right side better.
In the short-term collapse, it will hardly move at all. Improved access to the curve.
The disadvantages are only tight. Is very high maintenance
Share this post
Link to post
The next item is a wheel with tires, I chose the SSR MK-3 wheels.
Front Wheel Style 15 × 7.5J +19 Tire AD08 195 / 50R15
Rear Projection 15 × 8J -0 Tire AD08 205 / 50R15
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
