Ke70 Project
KTS front shock absorber with FC3S brake kit, which I assembled face shocks to fit into the daily use. And brake discs to be used as a mini R53 plate size 276 × 22 mm.
The next item is watt link of SSWork. From Japan
By the pros
Normal of the undercarriage, hard coil, general coil, time it collapses - stretch It will sweep to the bend.
It will cause the shaft to move its left-right side along its sweep.
But Watt's link, it will keep the shaft does not move the left-right side better.
In the short-term collapse, it will hardly move at all. Improved access to the curve.
The disadvantages are only tight. Is very high maintenance
They look great! Throw up some pics of the car they're going into!
The next item is a wheel with tires, I chose the SSR MK-3 wheels.
Front Wheel Style 15 × 7.5J +19 Tire AD08 195 / 50R15
Rear Projection 15 × 8J -0 Tire AD08 205 / 50R15
Cusco 116 473 A Pillowball Tension Rod Front Levin/Trueno AE86
Next item is a titanium twin end exhaust. 2.3 "I ordered a specially made for Toyota ke70.
