chiller75 Posted July 18, 2017 Report Posted July 18, 2017 (edited) what corollas share same bits as ke25 as an upgrade in terms of suspension. but still keepin the 4 stud Edited July 18, 2017 by chiller75 Quote
AE25 Posted August 17, 2017 Report Posted August 17, 2017 Very generalised question there. all rwd corollas after the e2 series had improvements made so usually there will be some benefit to changing to later gear. 4x114.3 (4.5") stud pattern is one benefit as was found on the te2 versions. bigger fr disk brakes from the ke3 is a relatively easy swap. otherwise different struts and steering knuckles is the most common id say. te2 steering knuckes with vented ae86 strut/disk is a good upgrade with a heap of aftermarket support for suspension and brake upgrades to suit. ae86 p/s knuckles can otherwise be used with ball joint collars if te2 knuckles are unobtainium. Quote
chiller75 Posted December 14, 2017 Author Report Posted December 14, 2017 Thank you for the response i have been away for a long time but now back on the project. Quote
