Ke30 grill inquirie
Hi Michael,
                    Welcome aboad !    Most  KE3X grills will fit on a KE5X models.  The only one you may have a slight modification to do, is if the KE5X you are fitting the kE3X grill to, previous had square headlights.
However, my belief is that the extra brackets etc. for the grill with square headlights, can easily be removed, & the gear & mounting points for round head lights were retained.
The harder conversion is the other way around, fitting square head lights & associated grill to a kE30, which, to my knowledge, were never offered with square headlights option.
I did this conversion a few years ago, & it was possible, by "finicky" !
Cheers Banjo
Link to comment
Share on other sites
