ok first post for me    other than the diameter of the clutch surface area      will a flywheel off a 6 /a carb engine AE90    fit a 4Af/e  engine  ie the crankshaft bolt holes????are they the same
The reason being i scored a carb gear box which has only done 40,000klm i know the clutch splines and diameter is different but need to know whether the bolt pattern for flywheel  is same
thanks for your help  please only reply if you know     no guesses or i think so thanks
