JiP Posted June 12, 2006 Report Posted June 12, 2006 Hey my ignition on my Ke30 is rather loose and i was just wondering if it were possible to tighten it?? It has two threaded type bolts coming through the bottom with no nuts on them, but there is no space for nuts anyway. Can you help?? thanks, Jon. Quote
thomo Posted June 13, 2006 Report Posted June 13, 2006 they are special "anti tamper" bolts, the heads snap off when the bolts are at the right tork, get them out but tapping them anti clockwise with a center punch, then cut a groove in the tops with a hack saw, then you can tighten them up with a flat head screw driver :thumbsup: Quote
