Hey fullas,
I bought a reconditioned long 4K motor the other day, and I'm getting the starter motor etc off my 3K, I'm getting a new water pump, and the whole distributor, also getting my radiator flushed, anything else that I may need to consider?
Thanks guys
Brad
Edited by Brad
carby kit or other carby(s) + manifold
id probably put a new regulator in the alternator while its out to
fan belt, leads, poss. coil, poss. engine mounts
I would probably give it an oil and filter change withing 500-1000 clicks as well, no point wearing it out too new.
And as much as I do not work for them, I have had good results from Nulon oil treatment. I had an old HR with a 186 and it was so much quieter, easier to start, much smoother running, dropped about 10 degrees F on the temp gauge, and improved fuel economy by about 2 mpg.
Might be worth considering.
Paul
