3t Gte Ke70
hay guys I'm building up a ke70 (daily drifter) and am wondering what kind of suspension setup and brake convo i will need to keep it road legal I'm planing around 150kw at the wheels.
from research i have found that RA60 struts bolt in and the brakes are much larger and vented. but with the ke70 lower control arm you end up with a positive camber. now apparently by using a Sigma lower control arm it changes produces a -4 degree camber (is this legal) which should be pretty good. just wanted to know if anyone has performed this conversion before and can confirm it fits well? i don't mind a bit of chopping here and there as I'm a sheety??
any help?
cheers
