Hello Guys,
Firstly Ive had my trusty 4k-e EFI starlet for a while now and it has had an intermitent tap in the top end for a while.
I pulled the hydraulic tappets to bits this week and discovered that the diaphram's inside and rooted. So they are back in the car.
Now I love my baby soo much that I need to keep her in a1 condition.
What parts will I need to convert a hydraulic tappet 4k, to cam followers and pushrods.
Will a 3k Solid lifter and cam follower work in a 4k hydraulic motor? Or do I need the 4k solid as a donor?
Are the rod lengths different in 2/3/4k's?
it's just a straight swap, what do you want for the old hydraulic ones?
Since I live in NZ that could be a pain.
is it a straight swap for a 3k or 4k's pushrods and cam followers? The 4k would have slightly longer push rods huh? Obviously I'll need to go to 12 and 8 clearances to run solid lifters.
