Search results
Page title matches
  • '''Ke55 Round Headlight Conversion''' If you use KE55 round headlights, use a KE55 round headlight grill, and if you use KE35 round headlights, use the KE35 g
    990 bytes (158 words) - 13:28, 13 December 2010
  • #REDIRECT [[Upgrades:Ke55 boot release]]
    40 bytes (5 words) - 03:50, 22 June 2008
  • KE3x/KE55 Boot Release
    4 KB (787 words) - 03:50, 22 June 2008
  • ...are. You will need to cut the lower spring perch off and re welded KE30 or KE55 lower spring perch on. You will need to use the matching Top spring hat and
    2 KB (387 words) - 12:49, 12 January 2011
Page text matches
  • *KE70: The same as ke55, Thicker than KE30 with Girlock brake calipers. 4x114.3 ...he same brakes so you may as well go for them, if not just try and get the ke55 backing plates and caliper mounts.
    4 KB (797 words) - 11:42, 18 September 2012
  • this is my FAQ on how to put a hilux/4 runner, diff into a ke30-ke55.
    418 bytes (86 words) - 09:18, 30 July 2007
  • The one on my KE55 has a different arm that sits on the cam compared to the KE70 I also have. One on the left is from a KE55 and one on right is a KE70
    2 KB (363 words) - 02:26, 16 September 2012
  • Information courtesy of KE30 KE35 KE55.
    649 bytes (104 words) - 08:36, 24 November 2010
  • <tr><td>KE55</td></tr>
    2 KB (363 words) - 15:14, 26 May 2008
  • The boxes on the KE55 models do not have a drain plug in their sump. So to drain the box you must
    886 bytes (152 words) - 02:22, 16 September 2012
  • *[[Series:K/Model/KE50/KE55/Template|Template]] *[[Series:K/Model/KE50/KE55/Ke55 Round Headlight Conversion|Ke55 Round Headlight Conversion]]
    9 KB (1,265 words) - 09:49, 14 September 2012
  • KE1x and 2x discs are 200mm x 10mm. KE3x discs are 218mm x 10mm. Australian KE55/70 discs are 218mm x 12mm. ...thicker disc provides better heat properties to resist brake fade. The Aus KE55/70 brakes also have a larger pad area.
    10 KB (1,927 words) - 12:33, 22 November 2006
    9 KB (1,341 words) - 09:31, 28 April 2014
  • 184 = Toyota Corolla KE55 Workshop Manual, 1300cc 4K-C (1978-1981)
    3 KB (385 words) - 02:15, 7 September 2008
  • ''Xany's KE55 5K Solid Lifters;''
    3 KB (603 words) - 02:16, 16 September 2012
  • KE10, KE20, KE30, possibly KE55 w/ 4 Spd KE55 w/ 5 spd, KE70
    11 KB (1,693 words) - 02:21, 16 September 2012
  • ...use for j-pipes as they have a single outlet. You could use a twin outlet KE55 style manifold but the j-pipe would be a bit more complicated and expensive
    14 KB (2,639 words) - 02:28, 16 September 2012
  • ...t seems to handle big revs alot better. The Bosch one fitted to Australian KE55-onwards Corollas makes 45A but old stock ones don't seem to be as hardy at ...u have certain KE70s. Jap tailshafts (KE10-30) and Borg Warner tailshafts (KE55-70) have different types of unis. You might want to get your tailshaft bala
    68 KB (12,724 words) - 02:28, 16 September 2012
View (previous 20 | ) (20 | 50 | 100 | 250 | 500)
