Ethan#4
Everything posted by Ethan#4
  1. The cam is a tighe which i brought last year, it is set on standard cam now with no difference down low (under 2000rpm)as of yesterday. The carby i would say is rich low down as it floods until above 2000rpm, it will not idle and it has a huge flat spot until, again, above 2000rpm. Changing the idle mixture does not change a thing. The ignition timing is set at 28 full advance not sure what at idle, and the engine wont rev immediately until above 2000rpm. Andy43 i have no idea what the anti dieseling solaniod is but i would say it is not connected as it is a speedway car?? Thanks for replys,
  2. Í've been having trouble with this new engine i put in recently... After beening started up the engine will run as if the dizzie timing is retarted, until it revs to 2000rpm. Once above 2000rpm it sounds and runs sweet. So today i thought i would change the cam timing back to standard( as it was set halve way around the cam sprocket) in hope to try and gain some more revs down below 2000rpm, this did not change a thing. Now after all hope was lost with that, we decided to turn to the carby, which is getting fuel after the engine is shut off??? I am totally stuck now as to what to do with this engine??? and the fuel pump is brand new. Help please....
  3. High compression is what i need as it is going to become a speedway race engine with tighe 493C cam.
  4. Yeah thats the one, can i put the head onto a 3k block without the dished pistons or would there be a problem?
  5. Hi all Recently i pulled down a 4k engine that had dished pistons and what looks like a bigport head. My question is can i buy new dished pistons? thanks for any help.
  6. Ok ill try and get down there to find the codes and i'll put it on a new thread.
  7. Its a 197Xs model also if that is any help at all.
  8. Not to sure think the motor is a r18 if that helps.
  9. Ethan#4 posted a topic in WA / Perth
    Anybody in perth and surrounding areas have ke30 parts. Struts, ke20 gearboxes, complete engines and complete cars are most needed. Thanks
  10. I'm thinking about buying this corona for parts for my ke30. Just need an idea on what parts will fit from the corona onto the ke30. If nothing does i wont buy it. Please Help thanks
  11. Just wondering how much for a Tighe Cam. Cheers
  12. Thanks this helps alot
  13. Hi Just got a 4 speed manual gearbox out of a ke20. Need the ratios on every gear so i can get a diff to fit. If you can help please do!
  14. Hi everyone Just trying to get some info on parts that will fit into a ke30. Any info welcome Thanks
  15. Thinking about biulding a new motor for racecar, but need a cam. I really would like a big cam to suit a 3k motor. What would be a good cam to run, any suggestions?
  16. Can anybody say what is the ratio of the 4 speed manual gearbox in a ke20?
