mourilyan
  1. Hey mate JHH built the motor, it cost 6000 to build it wich was everything it needed, just bolt on a 28/60 and a decent manifold and computer man and your there. but i guess it all adds up :)
  2. Yeah man i know leon he used to live around the block, great guy. Small world hey hahah
  3. Cheers bro..... not quite as much power as urs lol 35r is wild man is that just a little laggy?
  4. Ha ha cheers man those wheels are pretty cheap man :) thanks for the props
  5. Thanks man, yeah it is a bit of a handful lol not much traction . :)
  6. Hey guys, I have been building this car for around 5 years it was beige with a 16 valve and a bit of suspension work. Engine:4AGE 20 Valve Silver top Engine hardware Custom oil cooler kit and filter relocation kit, custom oil catch can and modified baffled sump. Nissan trx bluebird radiator with dual thermos, Ground and balanced standard crankshaft, 20 thou over boar with oversized weisco forged pistons 8.5.1, Shot peen and polished 4agze conrods with arp conrod bolts. Arp race bearings throughout, Arp head stud kit, Angular block modification for big end bearings, Aftermarket valve springs, multilayer metal head gasket, bush bearing 28/60 turbo, 38mm external waste gate and screamer, Custom plenum chamber with 3sgte throttle body,1jz injectors, Adaptronic ecu, ae101 coil packs, Straight through 2.5inch side pipe, Custom surge tank with braided line and bosch 044 fuel pump custom surge tank and fuel cell. Drive train W55 Celica gearbox, 4 puck ceramic clutch, E series light ace diff locked and converted to disk with s13 disks with 4.3 diff gears. One peace tail shaft. Brakes/Suspension Front-Custom made front coil overs with 8kg swift springs and kyb agx 4 way adjustable shocks, Ajps front sway bar, T3 camber tops and custom strut brace, Ae86 power steering arms, Sigma lower control arms and t3 RCAs. Jdm vented rotors with braided break lines. Rear- Custom made coil overs using 6kg springs and kyb agx 8 way adjustable shocks and a T3 rose jointed adjustable pan hard rod. Rear Ajps Sway bar and Ajps traction brackets, Nolothane bushes throughout car. s13 rear disks. Wheels and tyres 15 by 8 -4 Super lights all round with 195 50 15 nankang ns2s for now. Bodywork Hand flared guards front and rear, Repaint in Alpha Romeo Silver. Interior S15 dash fitted with digital sabre gauges and ace well digital dash, Bride recliner for driver and passenger and Trust harnesses, kkr deep dish suede steering wheel, Trust gear knob. Jap spec turbo timer and custom made hydraulic hand brake and line lock kit. Car puts out 201.9kw's at 16psi plenty more to come :)
