36 wags
  1. just letting use all know at motor and box bolted in,started to wirer up motor and strip wires that not needed and clean as possable and cleaned the oringal ke36 wiring up aswell and new fuel system in just need hooking up and doing a diff upgrade aswell to a rn40 hilux and ive already done s13 front end suspension just need to change hubs to five stud ones and hoping to post some pics soon for uses
  2. u just need to make engine mounts uo and a gearbox mount aswell had to do it for my ke36 wagon no need to pump out the gearbox tunnel
  3. got my engine mounts today hoping to have motor in by tuesday
  4. engine mounts and gear box mounts should be made by next week then the fun will start but I'm still having trouble with brake booster upgrade and master cyclinder but still havent made my mind up about diff conversion and abount 4 or 5 stud??????
  5. getting a ae86 crossmember going to see if that would bolt up with some modifcation to ke36 rails if not it back to waiting for my brother mate to make them up
  6. its good to see someone else doing the same conversion as me
  7. cheers crowie but just brought s13 complete front end with coilovers so doing that for now and found myself some rwd intake and exhaust mainifold and just putting a U pipe on for the water outlet
  8. just got a spare ke36 wagon but striping it so mite have some parts for sale like 2 4speed gear boxes and other so if u need somethink let me know
  9. would xt130 front struts and brakes setup would suit the 4age in my wagon
  10. just looked at ya boster upgrade and i wont be able to do that as my engine bay all ready sprayed but ive got another one i can try what modle parjero it the resorvar from only if ya know thanks and ill post more pics today
  11. just done my hydraulicy clutch setup used a ta22 celica clutch cylinder made it to fit only took about 3hours to do then had the fun part of putting back into car now working on what brake booster to use and master cylinder aswell for vt brakes,hubs up front and a vn lsd diff in the rear and hears some pics if it will let me put them up
  12. hi guys and girls not going 5 stud any more just staying with s13 front and standed diff till it packs it in and then going skyline diff after that . just renewed all steering parts this weekend now waiting on other parts befor motor put in its a 4age(86kw) got a t50 gearbox to go behind it and ill keep use updated and ill put pics up soon for use
  13. ok thanks mate and getting custom made suge tank to fit in the side of the boot and getting a hilux diff to fit under it aswell and thanks for your help (crowie55)
  14. all wireing got my brother and to work that one out and tailshaft was know to be custom and just wanting to know what pedal box is needed or can i just use standed and get a hydraulic setup to bolt to standed pedal box and thanks crowie for ur help
  15. havent heard the motor running yet but it only going to be there to get every think set up then going to save for 100kw 4age and for fuel just want to ezayest upgrade as possable and to look clean aswell once pannels r put back on ill takes some pics for use on here
